testing compression while motors on bench?????
- trianglelaguna
13 May 2009 13:32
i have a z-1900 sitting on my workbench......i have everything bolted and torqued,no pipes,ign plate,or carbs mounted......and a tie ratchet strap to secure the motor to the bench top ......i have a thread in dial guage with a button to release pressures......
can anyone explain if my battery and the guage will turn the starter and give readings....do i depress the comp gage button while cranking....do i ground the battery to the motor and hook the positive terminal to my starters black wire????
ect....ect......never done a compression test and also the motors out on my bench....thanks guys.....i know it is a stupid question but im learning here...thanks craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
Re: testing compression while motors on bench?????
13 May 2009 14:16
trianglelaguna wrote:
Craig
You are correct on the battery hook up. I would use the starter relay in the hook up. Screw in the gauge and don't touch it. The button is to release the pressure when you are done. Hold the throttle wide open while cranking. Thats all you need............
Craig
- trianglelaguna
13 May 2009 15:19
thank you....i guess a rigged way might be to strap the motor down to my bench in case it wants to tip from revolution inertia...and run a couple hevier guage wires from my bikes relay to the 2nd pulled out motor on my bench..(6 feet) and i could use my starter button to crank and stop cranking aye........o.k here goes i'll try fri and see what #s i can read....thank you...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- PLUMMEN
13 May 2009 16:39
you dont need no button,use aset of jumper cables and just bump it over!
- APE Jay
- PLUMMEN
14 May 2009 21:37
spoil sport! :laugh:
