Looking to fix my Muffler, suggestions wantedd
- The Garbone
- User is Currently waiting for his bailout check..
11 May 2009 18:49
Just bought this fixer upper...:huh:
I want the bike to be somewhat quiet and the pipe came with no baffles.
What should I do?
Buy new baffles? Where do I get them?
Replace with a low cost muffler from JC Whitney? Would this be as cost effective as a new baffle?
Any help would be appreciated...
What should I do?
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
- Pro_window78
Re: Looking to fix my Muffler, suggestions wantedd
11 May 2009 19:13
Do you know what kind of pipe it is?
- kano
- Not Another Bloody Limey!
11 May 2009 19:16
buy a new muffler look on ebay dude!
make sure you get the right size connection.
- The Garbone
11 May 2009 19:28
I think its a Vance and Hines 4 to 1.. There is no telling.. The previous owner said he got it off a 1000...Went to the local salvage yard and came up with nothing that matched...
The bad thing is that its welded on and not clamped.. I will probably have to have a shop do the work and I think that will run up the bill....
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
- kano
11 May 2009 19:34 - 11 May 2009 20:27
you asked for advice,
and i don't want to come across as a arrogant englishman but
you came here to learn,
you are surrounded by ppl who know these bikes inside out.
they would say im sure,
buy a system new or used dosn't matter,
4 into 1 Header with muffler
buy some new copper rings from z1enterprises can of wd40
and a 10$ socket set and get to work bro.
shops charge bucks, big bucks that's how they make their living
you i can guarantee will get great satisfaction from doing it yourself.
don't forget to post pictures plummen can't read.
Last edit: 11 May 2009 20:27 by kano.
- Pro_window78
11 May 2009 19:40
Hahahahahahaaha nice dig! Is it just too loud without a baffle? I have a kerker w a "race" baffle and it sounds great! If your going to go new, you can't go wrong w a kerker. If you want a quick fix, you could use some self tapping screws and some cheap steel strap and shove some steel wool in behind it. Doesn't look so good but it will quiet it down.
- The Garbone
11 May 2009 20:27
Just too loud... Gonna use it to tow a hack and my monkeys probably would not appreciate the noise.
I was hoping for someone to say "sure just go here for a baffle, it looks like it an xxxxxx pipe.. " Oh well, a new pipe and welding is probably in my future.... Another budget hit.
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
- kano
11 May 2009 20:30
roy the boy did make a baffle do a quick search to find his post.
i also added so links to my post above may help.
- Bluemeanie
12 May 2009 05:56
How about an angle shot of the end of the muffler? Baffles are still available for V&H and Kerkers.
- JMKZHI
12 May 2009 06:18Please Log in or Create an account to join the conversation.
- The Garbone
12 May 2009 09:42
JMKZHI wrote:
You sir are a King among men... I have found my solution and it is not chrome.....
1979 KZ650 & Hack
1949 Ford 8n
1979 KZ650 & Hack
1949 Ford 8n
