When I split my case I notices the large bearings on the output shatf and secondary shaft have spun in the canse a bit. There is clear evidence of the outside bearing race turning. The damage is minor but is this normal, or an indication of a problem? There are half circle clips on each bearing and I assumed they are supposed to lock the outside race from spinning?
By
t_f_b
, shot with
Canon PowerShot SD400
at 2009-05-03
"74 Yamaha DT 400 Enduro
