Clutch adjustment help KZ1000
- Alabaster
- Dallas, TX
10 May 2009 09:03 #289845
by Alabaster
'07 Ducati SC1000S
'79 KZ1000
Clutch adjustment help KZ1000 was created by Alabaster
Hi all,
I recently replaced my clutch packs and springs in my 79 KZ1000. It now makes a faint knocking sound when running. Is there any adjustments that need to be made after I got the back together running? Thanks in advance.
'07 Ducati SC1000S
'79 KZ1000
- Pro_window78
10 May 2009 21:55 #290107
by Pro_window78
Replied by Pro_window78 on topic Clutch adjustment help KZ1000
Don't those parts need a spell to seat properly? or wear in?
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
11 May 2009 01:04 #290151
by kzz1p
Replied by kzz1p on topic Clutch adjustment help KZ1000
Alabaster wrote:
Did you adjust the new clutch? Does the sound go away when the clutch is engauged?
Hi all,
