- Thank you received: 337
750 won't red line - Valve?
- bountyhunter
10 May 2009 16:04 - 10 May 2009 16:05 #289944
by bountyhunter
Replied by bountyhunter on topic 750 won't red line - Valve?
piperbill2 wrote:
A lean condition can burn things in the engine, but I don't know if you burned a valve. I think you would have low compression on a cylinder if the valve was burned.
IMHO, those are the symptoms of a lean running condition from main jets. You might try a stock airbox as it will probably run better.I also jetted up the carbs and put a sports air filter on and a new 4 into 2 exhaust.
After all this the bike pulled real well up to (I can't remember exactly) about 5000? but then would not go any faster. About 70 MPH is all she would do.
My questions are: What are the symptoms of a burned valve? The bike starts first hit on the starter and runs very smoothly. It just won't go to red line under load or even near it.
Last edit: 10 May 2009 16:05 by bountyhunter.
- Pro_window78
10 May 2009 21:47 #290102
by Pro_window78
Replied by Pro_window78 on topic 750 won't red line - Valve?
Yeah, either a stock airbox or bigger main jets would be my guess.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
11 May 2009 01:08 #290152
by kzz1p
Replied by kzz1p on topic 750 won't red line - Valve?
When you have it wide open and it will not rev anymore, try just alittle choke. If it runs better, install larger jets.
