locating 2nd gear shift fork..
- brianrae33
09 May 2009 14:09 #289420
by brianrae33
1982 kz1000ltd
locating 2nd gear shift fork.. was created by brianrae33
going to pull my oil pan next week and check my shift forks and 2nd gear..pretty sure there are 3 shift forks in the tranny..two large diameter and one small diameter..correct?just wanna make sure i'm checking the right stuff..
1982 kz1000ltd
- PLUMMEN
- Thank you received: 104
09 May 2009 17:08 #289501
by PLUMMEN
Replied by PLUMMEN on topic locating 2nd gear shift fork..
3rd gear is on drum,i want to say 2/5 is on countershaft sprocket side when looking at other two,havent looked at a trans in a while. :S
- MFolks
- Thank you received: 540
09 May 2009 20:18 #289588
by MFolks
Replied by MFolks on topic locating 2nd gear shift fork..
Try this website:http://www.kzzone.com/trans.html
- brianrae33
10 May 2009 06:51 #289770
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic locating 2nd gear shift fork..
from what i can tell all three shift forks look damn near identical with the exception of where they go over either the shift drum which is large and the one smaller diameter one..i actually half hope it is so bent that it is very obvious...keep me from guessing what to order..
1982 kz1000ltd
