- Thank you received: 3
I need some input...
- hardr0ck68
- Who put the what in the where?
First of all, compression is unknown...I know I need to check it.
A 4 into 1 pipe and pods have been added and I have yet to re-jet
Valves are all shimmed except one which has a clearance of .20mm, I don't happen to have the size smaller sooo it will have to do for now.
Ignition timing is spot on (according to the cheapo timing gun I got at princess auto)
Cam timing, well it is as close as I can get it... I tried 3 times tonight to get it spot on, but I am guessing wear of the cam chain has made it impossible to get both timing marks spot on...
Now the problems,
1) plugs #2 and 4 were black and carbon covered while plugs 1 and 3 were white (what I expect because I have yet to rejet for the pipe and pods). What could make those 2 foul.
2) no power over 7,000 RPM's it will sometimes surge with a moment of power then go flat again...
3) poor idle, it does idle reliable at 1,000 rpms it just sounds bad, and I can hear a sucking from one side of the carbs.... also adjusting the air screws on the carbs does not seem to make any difference which I find odd.
I think my next step should be to go up some jet sizes (2 or 3?) and sync the carbs. DOes anyone have any other input?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- roy-b-boy-b
- Thank you received: 103
Swap out the plugs you now have installed.Put 2 and 4 in 1 and 3 and see if they change colors.
Are your carbs clean?
Just some thoughts. Roy
- Thank you received: 2098
An otherwise perfect carb will suffer from an incorrect fuel level.
Some pods obstruct entrance to pilot air passage.
Dirty, clogged or over-oiled pod can cause sooty plug by restricting air intake.
Could be wrong, but doubt carb sync would resolve soot issue on #2 and #4 plugs.
Air screw adjustment having no effect indicates something wrong in the pilot circuit.
Good Luck!
- BSKZ650
- Thank you received: 14
also have you checked the voltage at the coils and check the coils also.
I would replace the plugs with new ones, dont just try and clean them, just dosent work anymore.
what have you done to the carbs if anything? a good cleaning is going to be very important, and replace the fuel filter also
77 ltd1000, current rider
76 kz900, just waiting
- hardr0ck68
I have checked the fuel level with a tube, but with pretty poor results. I picked up the special tool and I plan on checking the float bowl level properly when I pick up some jets.
I have not checked coil voltage I will check that next time I am working on the bike.
1977 kz650 c1
- BSKZ650
The carbs are clean, I have checked them at least 3 times and run thin wires through all the passages.
I don't suspect coil voltage, because the two sooty plugs are from different coils.
Until assured otherwise, I would still suspect pods obstructing entrance to pilot air passage at rear of carb. Especially if not using K&N pods. Usually not an issue with K&N pods.
Imo the plug sooting issue should be resolved before installing larger pilot jets which will just worsen the sooting problem. Using the clear plastic tube test to check floatbowl fuel level may be performed with the carbs remaining installed on the bike and without any disassembly (except removing the drain screws).
Good Luck!
- buckinrut25
- hardr0ck68
I just dropped in the new jets today, and I picked up some fresh plugs. My new stainless pipes were bluing so I decided it was time to fix this lean condition.
I checked the float levels #1,and 3 were perfect. #2 was a touch high but close enough, and #4 was fairly low so I adjusted and now it is spot on.
I am now running 107.5 mains, and whatever pilots z1 recommended.
Is it worth the work to change the needle height?
Other information. I have checked for intake leaks many times, to always find all the boots sealed up tight.
Still wondering why those two are sooty...
If the pods are blocking the pilot circuit how do I fix it? And is there any way to check? How do I fix the problem without dropping $140 on K and N pods? I have emgo pods if that matters.
1977 kz650 c1
- gane
[img][/img] 1977 KZ1000A1
- Pro_window78
- hardr0ck68
I agree Gane, I doubt this is ignition related either however; would a combination of poor spark (maybe incorrect coil voltage) and was also running lean cause some plugs to be white and others black?
I just took it for a ride with the new jets... some good some bad. The midrange seems more powerful, It is night and I didn't wanna kiss a deer so I cannot comment on WOT yet except when I peg the throttle open quickly the bike stumbles now... this was not a problem before.
Overall it feels better, except for the stumble when I go to WOT.
1977 kz650 c1
