KZ1000 Valve clearances
- Pro_window78
07 May 2009 18:06 #288890
by Pro_window78
KZ1000 Valve clearances was created by Pro_window78
I have a 78 kz1000 and I just measured my valve clearances. My number 2 cylinder on the exhaust side has under .05 and my intake side is tight on the .05mm feeler gauge. The rest are all between .05 and .08. My question is, what size shims do I need? How do I tell what size is in there? Thanks
- Old Man Rock
- Thank you received: 225
07 May 2009 20:23 #288943
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic KZ1000 Valve clearances
Normal protocol, the under side of the shim has the shim number size stamped on them.... If in doubt, use a caliper and measure the shims thickness....
You want between .05 to .1mm....
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
07 May 2009 20:25 #288944
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Pro_window78
08 May 2009 06:58 #289020
by Pro_window78
Replied by Pro_window78 on topic KZ1000 Valve clearances
Awesome!! Thanks a ton!!
