Starter drags when idled correctly
- abe75000
07 May 2009 13:54 - 07 May 2009 13:56 #288791
by abe75000
Starter drags when idled correctly was created by abe75000
I have a starting issue with my 83 kz 750. When it is idled according to specs, starter drags, when i idle it down low say around 600rpm which I think is to low for proper engine lubrication. the starter does not drag when i use a 600 or lowere idle.. can anyone help me on this. starter is not at fault as i have tried the starter off of my other kz and it does the same thing. could it be the starter solonoid causing this? thanks for any help. bye
Last edit: 07 May 2009 13:56 by abe75000.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
07 May 2009 17:21 #288857
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Starter drags when idled correctly
I would think to check the starter clutch assembly. I'm pretty sure the engine shouldnt drive the clutch at all if it is torqued/lubricated properly.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
07 May 2009 17:24 #288860
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
