- Thank you received: 5
Kz900 - 1000 Parts interchange question.
- dshelly
06 May 2009 14:54 #288537
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Kz900 - 1000 Parts interchange question. was created by dshelly
Hi all,
Anyone know if the exhaust flanges from a '78 kz1000 will fit on a z1 or 900 . Other than the stud holes being larger. is the center to center distance the same, and the recess for the split collars?
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- otakar
06 May 2009 15:13 #288541
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Kz900 - 1000 Parts interchange question.
How can I put this simply.:silly: Yes, Yes, & Yes.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Thank you received: 2098
06 May 2009 15:27 - 06 May 2009 15:29 #288550
by Patton
Replied by Patton on topic Kz900 - 1000 Parts interchange question.
dshelly wrote:
otakar is 100% correct.
They're interchangeable.
Larger studs were introduced on 1977 KZ1000.
Am thinking starburst design continued through 1980 until replaced in 1981 with the plain smooth design.
Both sizes and design styles are available at Z1E.
Here are the plain style on my Z1.
[Click on image to enlarge view]
Good Luck!
Hi all,
Good Luck!
Last edit: 06 May 2009 15:29 by Patton.
- dshelly
07 May 2009 08:52 #288731
by dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Kz900 - 1000 Parts interchange question.
Thanks alot.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
