1982 KZ650 cranks but won't start
- mccormack090305
- buckinrut25
- mccormack090305
- buckinrut25
- mccormack090305
- The Garbone
- User is Currently waiting for his bailout check..
I would check your manifold between the carbs and engine to make sure everything is tight and crack free.. An airleak there will cause issues..
Is the gas new? Some of these reformulated oxidized mixtures sour pretty fast and if it has ethanol you might also have collected some water.
To start I would pull the carbs and make sure all the channels are clear and while they are out pull the throttle cable and lube it using the foil funnel method.
Just my .02..
2007 Royal Enfield Iron
1979 KZ650 & Hack
1949 Ford 8n
- Thank you received: 2829
- baldy110
- Thank you received: 512
- mccormack090305
- mccormack090305
- mccormack090305
- anarki650
I also, in the whole process of cleaning and trying to get this thing running, replaced the stock airbox with the pod filters. I read a lot about it, and most people advised against it, but I really wanted to try it out. I also read that without pipes and jetting, it wouldn't do much in the way of performance. Would that maybe lean it out too much? Maybe when I have the carbs off, I should jet it. I plan on putting an exhaust on as soon as I can afford it. What do you suggest as a basis for jetting with the setup I have now?
If you put pods on you definitely need to rejet the carbs. The intake on these bikes effects the jetting requirements WAY more than the exhaust does. On my old 81 kz650 (mikuni vm24 carbs for reference) with the airbox and stock exhaust I was running 102 mains and 15 pilots, when I switched to pods (still running stock exhaust) I had to bump those up to 112.5 mains and 17.5 pilots, so that's 4 steps larger main jets and one step larger pilot jet.
In 82 I'm pretty sure you've got the Kienen carbs, so my jet figures won't help you any, and I don't know anything about those later year carbs to suggest jetting changes, but you definitely have to rejet that.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
