running on 3 cylinders KZ 1000ST
- KOOL RYDER
- KZ 650B2 / KZ 1000E
06 May 2009 12:11 #288504
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
running on 3 cylinders KZ 1000ST was created by KOOL RYDER
KZ 1000ST
Went for a ride ~ 200kms felt great until I hit city traffic and noticed there was a lack of power. More like my 650.
When I got home I did the h2o spary test, instant steam on 1,2,3 but it ran down the #4 exhaust pipe.
My question is - Could this be the result of a fouled plug? or is it more likely coil or plug wire related.
Shold I ground the plug on the valve cover and look for a fat spark?
Any advice would help.
1978 KZ650B
1979 KZ1000ST
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
06 May 2009 12:18 #288506
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic running on 3 cylinders KZ 1000ST
It could be result of a fouled plug, i would ground the plug and look for a spark. But if the plug looks fouled, i would take some starting fluid and spray the tip in an effort to clean the elecrode of carbon.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Russ Jackson
06 May 2009 12:45 #288510
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic running on 3 cylinders KZ 1000ST
Change the plug. Start it up. Pull the wire. If the idle speed changes you have your answer. Check to see if the plug wire pulled out of the boot. I doubt it is the coil...Russ
- Thank you received: 2098
06 May 2009 12:46 #288511
by Patton
Replied by Patton on topic running on 3 cylinders KZ 1000ST
KOOL RYDER wrote:
Yes, using a brand new plug. Poor spark quality indicates an ignition problem.
If spark looks okay, would check floatbowl fuel level using clear tube test. Especially to assure it isn't too high, which can cause excessivly rich mixture in otherwise perfect carb.
Would also perform compression test and assure valve clearances being to specs.
Any issue with the above components should be corrected before further addressing carbs.
Good Luck!
...Should I ground the plug on the valve cover and look for a fat spark?....
Good Luck!
- 88alltrac
06 May 2009 14:19 #288531
by 88alltrac
81 KZ1000 K1
Lincoln NE
Replied by 88alltrac on topic running on 3 cylinders KZ 1000ST
ah this sounds very familiar. just got mine running on 4 again. thanks to some very useful advice from patton.
yea after putting in a new plug ground it and see what the spark looks like. then report back here if you dont know what to do next.
81 KZ1000 K1
Lincoln NE
- 88alltrac
06 May 2009 14:21 #288532
by 88alltrac
81 KZ1000 K1
Lincoln NE
if you do have a fouled plug chances are pretty high that changing it will only fix it temporarily until it fouls again.
81 KZ1000 K1
Lincoln NE
- KOOL RYDER
07 May 2009 08:54 #288732
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
Replied by KOOL RYDER on topic running on 3 cylinders KZ 1000ST
Thanks dudes.
I will swap it out and ground it. One question though....
How do I ground the spark plug without blowing myself up?
Would I start the bike with the plug out and then bring it in contat wih the valve cover?
1978 KZ650B
1979 KZ1000ST
- osride
- Blog: http://classicmotorbikes.blogspot.com/
07 May 2009 09:02 #288734
by osride
Replied by osride on topic running on 3 cylinders KZ 1000ST
Just insert the plug into the wire end and set it on top of the engine. You really shouldn't even have to start it up, just crank it over and that should give you the answer.
07 May 2009 09:54 #288744
by Patton
While testing #4 plug to visually observe spark quality, should leave #1 plug screwed in and connected as usual, but okay to remove caps on middle plugs #2/3 during the test.
Good Luck!
Good Luck!
- KOOL RYDER
11 May 2009 09:14 #290184
by KOOL RYDER
1978 KZ650B
1979 KZ1000ST
I figured that my bike was running on 3 cylinders and did the spray test. Sure enough when I pulled he plug on #4 it was all gummed up with what appeared to be grease. The oil had built up that bad.
After taking a closer look, the shop that did the safety inspection on my bike had installed BR8ES plugs rather than B8ES. (This is one more in a long line of screw ups that I have experienced at bike shops.)
Anyways bought new plugs and installed. $12.00 later that bike is running as it should, a follow-up inspection of the plugs show a little carbon build-up, but not enough to cause any concern.
Thanks for the help
KRB)
Thanks for the help
KRB)
1978 KZ650B
1979 KZ1000ST
- timebomb33
- Thank you received: 10
11 May 2009 12:46 #290228
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic running on 3 cylinders KZ 1000ST
the only difference between those two plugs is that the br8es is used to cut down on radio or electronic interferance in your bike you should be able to use either one. the r stands for resistance.
