- Thank you received: 28
Shim Question...
- TeK9iNe
- What did you do!?!
How can I determine the shims I require if I have no valve clearance at all?
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- TeK9iNe
Now I'm stuck with no clearance on any shims, and the valves are all "a hair" open.
Me thinks I'm going to have to get a really thin reference shim somewhere, then spend the hours moving that shim all over the head to find my clearances. Think this will work?
Thanks!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- RonKZ650
- Thank you received: 240
- timebomb33
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
I'd install a 200 shim (the thinnest available) and remeasure. If you don't have sufficient clearance with that, then it's time to start looking for a new head (or have new seats installed--or valve stems ground)
West Linn, OR
- bountyhunter
- Thank you received: 337
- bountyhunter
In the future, you should write down the shims at each valve going into the head job and tell them the limit on shim size available. That way they will measure valve end height before they start. After cutting the seats, they will grind the valve ends to try to hold the original height or at least make sure it is within service range of available shim sizes.Iv'e got no spin at all. The seats were so bad that they had to cut them pretty deep.
- Old Man Rock
- Thank you received: 225
I was wondering the exact same thing.... Pop one/all out and measure with a caliper.... Go from there...What size shims do you have in there now?
Same time as bounty hunter mentioned, Larry C did my valve/head work and informed me exactly what I would need in shims when I got the head back.... Surprised your machinist didn't provide the same....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- TeK9iNe
Measured all the shims, and they are ranging from 2.82 - 2.67 Not bad for 45 thousand k.
Wish I had done things different now...
As a side note, I may have found someone local to either exchange shims, or have him look at my head. Just waiting on a call back...
Thanks for replies,
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- TeK9iNe
He even gave me the origional Kawasaki Shim tool to use :lol:
235 - 250 average range now...
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
