- Thank you received: 2
TO OIL OR NOT TO OIL...THIS IS THE QUESTION.......
- keith1
04 May 2009 18:36 #287983
by keith1
TO OIL OR NOT TO OIL...THIS IS THE QUESTION....... was created by keith1
i have always been under the impression that pods, k and n in particular, needed oil to function as designed.....i have seen info to the contrary...input?....not war mongering...just wondering the general consensus.....just ordered a set of k and n 's..........thanks as always......keith
- Buda
04 May 2009 18:46 #287987
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic TO OIL OR NOT TO OIL...THIS IS THE QUESTION.......
I oil my k&ns. I thought that was the deal with k&ns lasting so long because you can clean and re oil them.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- RonKZ650
- Thank you received: 240
04 May 2009 18:52 #287990
by RonKZ650
Replied by RonKZ650 on topic TO OIL OR NOT TO OIL...THIS IS THE QUESTION.......
The oil is what catches the dirt. Without oil dirt will be ingested. K&N even with oil will let gobs of dirt flow into the engine, but without oil will be much worse.
- PLUMMEN
- Thank you received: 104
04 May 2009 20:26 #288025
by PLUMMEN
Replied by PLUMMEN on topic TO OIL OR NOT TO OIL...THIS IS THE QUESTION.......
my dad had the k&n cleaner analzed at a lab years ago,save your money its same as 409!
