KZ fuel injection
- Captaingamez
KZ fuel injection
04 May 2009 14:03
How easy would it be to fuel inject a 79 mkII, if you had a set of throttle bodies off of a 1980 KZ1000 that was factory fuel injected. more specifically what kind of ECM could you use to run it? anyone have any experience playing with other bikes ECMs on KZs?
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
1971 Yamaha AT1
1971 Skiroule 300rr
- School Teacher
Re: KZ fuel injection
04 May 2009 20:11
well it would be tough because the injectors go in the head on that bike, though i see the heads on ebay dirt cheap. i have that bike.(i screwed up the head and went to carbs) but you could use the 81 gpz fuel injection system without changing you head
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- MFolks
04 May 2009 20:22
Find a set off an 82 GPZ1100, Kawasaki moved the injectors to the throttle bodies to reduce overheating. Many guys are going the Mega-squirt way of FI.
www.msefi.com/viewtopic.php?f=29&t=6627
www.diyautotune.com/catalog/index.php
www.dropbears.com/bikelinks/Parts/Fuel/fuel2.html
www.dobeckperformance.com/default.asp
- PLUMMEN
04 May 2009 21:05
how much hp will the gpz injectors support? i remember the injectors on my84 gpz being a pain but that was before all the aftermarket controllers came along
- larrycavan
05 May 2009 04:06
The Microsquirt is the ECU you want for that project.
www.diyautotune.com/catalog/microsquirt-c-35.html
D.F.I. throttle bodies and injectors are what you want so it's 82 - 85 GPz11 for those. Other, newer setups can be adapted.
The stock throttle bodies can be greatly improved in the CFM department. Pogue Machine in Oklahoma will, I believe, still do them. Get their adjustable fuel pressure regulator as well.
You'll need fuel pump, engine temp sensor, resistor pack and other assorted items. It's not a small project but it has been done by good number of people.
Before you start, sit down with the Microsquirt docs, read the forum links provided above and figure out exactly what plarts you'll need.
As I recall, Sid ran the stock injectors on up to 1428cc but had to use 2 fuel pumps.
Get yourself a copy of the Motorcycle Fuel Injection Handbook too. ISBN# 0-7603-1635-X
- roy-b-boy-b
05 May 2009 05:10
There is a 1980 Z1 Classic on eBay now being parted out. Roy
- larrycavan
05 May 2009 06:05
roy-b-boy-b wrote:
You really don't want that old analog stuff. The air gate setup has issues. Stick with DFI.
- zippy
05 May 2009 09:46
Captaingamez wrote:
Try here for almost one stop shopping.
www.hilborninjection.com/product.asp?Id=58&CatId=180
or here
www.kinsler.com/page--Home-Page--13.html
Seth Moore
or here
Seth Moore
