- Thank you received: 5
Exhaust leak symptoms
- jordan
03 May 2009 18:59 #287641
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Exhaust leak symptoms was created by jordan
I have been working on getting my buddy's kz1000 up and running good for him. The exhaust doesnt seal very well at all, and when bolted up it barely sits an inch or two off of the ground. It seems as if it were not even meant for this bike. He ordered a sidewinder, but in the meantime i was wondering how a bad exhaust leak would effect performance. It leaks pretty badly and sounds like a loud flap when riding. As for how the bike runs, it will run good when giving it just a little throttle, but there is a big spot throughtout the rpm range where it just stutters badly, and begins running better up top. Would the exhaust leak be causing this problem, or is it most likely the carbs?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- timebomb33
- Thank you received: 10
03 May 2009 19:01 #287642
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Exhaust leak symptoms
most of the problems your suffering are related to carb's the exhaust can have an effect on the way the bike performs for sure but most the problems will be carb related.
- jordan
03 May 2009 22:55 #287730
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic Exhaust leak symptoms
the petcock on this bike is a dual outlet, while there is only one fuel inlet on these carbs. Will one outlet feed these carbs efficiently? Also, the 3 nipples on the sides of each carb body, are they just overflows?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- TeK9iNe
- What did you do!?!
- Thank you received: 28
04 May 2009 05:58 #287757
by TeK9iNe
I Have to agree with timeomb33, this sounds carb related. I had an exhaust leak, and it was just loud and annoying. When fixed, it did give me a very small boost in power though...
Yeah, it should if your tank is venting ok. If not then you can always get a T adapter...
Cheers, goodluck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Exhaust leak symptoms
Cheers, goodluck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
