ZN1100 cam chain noise??
- sg56k
03 May 2009 07:56 #287436
by sg56k
ZN1100 cam chain noise?? was created by sg56k
Hi, I was wondering how to replace the cam chain guides on my 1100? I here the chain tinkling but the tensioner is not all the way extended so I thought maybe the guides are wore. The bike has 25k miles on it so far. Any help appreciated.
- Maltraxxx
17 Jun 2010 15:42 #376397
by Maltraxxx
Replied by Maltraxxx on topic ZN1100 cam chain noise??
I can hear the same thing on mine. Any clues, anyone?
- kawsakiman
- Thank you received: 6
18 Jun 2010 05:55 #376556
by kawsakiman
Replied by kawsakiman on topic ZN1100 cam chain noise??
the head has to come off.
before you go to that extreme have you tried the ape manual tensioner yet?
if you decide that is your only option i would check your valve clearances while it's off and bench shim the head.
you might even want to think about new valvesprings if you willing to go that far.
but for me i would try the tensioner first.
- otakar
18 Jun 2010 06:07 #376561
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic ZN1100 cam chain noise??
The automatic cam chain tensioners on the "J" series motors are susceptible to a extremely high rate of failure. Virtually everyone replaces them with a manual tensioner from APE. They are available from Z1E in New York or from Pit Stop Performance in Orlando. Just ask anyone at ZIE (315-926-5054) or Joe at Pit Stop that you require a tensioner for a "J" engine. I just had to replace mine for the same reason.
Joe Hooper
3213 Paisley Circle
Orlando, Florida 32817
joehooper@cfl.rr.com
407-679-9116
Joe Hooper
3213 Paisley Circle
407-679-9116
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
