clutch basket nut
- jzanutto
03 May 2009 07:14 #287430
by jzanutto
1978 KZ650B 2004 BMW R1150RT
clutch basket nut was created by jzanutto
78 KZ650B -in the diagrams I cant seem to find a good picture of the clutch basket nut- does it just use a fiber lock or is there also supposed to be a tab washer that gets bent over?
- Mark Wing
- Thank you received: 22
03 May 2009 10:45 #287468
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic clutch basket nut
There's a lock washer that goes on only one way with the marks facing out then the nut torqued to 80-108 foot pounds. The manual says to use a new nut but I never have.
Mark
Mark
Yorba Linda Cal.
- jzanutto
03 May 2009 11:48 #287486
by jzanutto
Replied by jzanutto on topic clutch basket nut
yeah I pulled it off to see. my outer clutch basket has a little freeplay even when that nut is all torqued.
anyone else have this?
- Mark Wing
03 May 2009 13:18 #287514
by Mark Wing
Yorba Linda Cal.
Just checked one I have and it has a small amount of play. I sure it's normal.
Mark
Mark
Yorba Linda Cal.
- mzandmz
24 Jul 2009 22:18 #309191
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic clutch basket nut
There is cushining pads between the gear and the clutch basket that allows it to help shift more smoothly. My '77 has a little play as well. 9942 miles on it Normal
