Engine Rumble
- littlemanonbigbike
30 Apr 2009 05:40 #286469
by littlemanonbigbike
1982 1100 Spectre
Various other toys
Engine Rumble was created by littlemanonbigbike
Good morning all. After rebuilding the top end on my bike and after about 50 miles of riding i have noticed a rumble in the motor that seems to be coming from the bottom end around the bevel gear cover. Any ideas?
1982 1100 Spectre
Various other toys
- timebomb33
- Thank you received: 10
30 Apr 2009 05:52 #286473
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Engine Rumble
it's been a long time since i've even worked on aa shaftie but check to see if there is oil in the middle drive housing hopefully sometimes if the rear seal dosen't get put in correctly,the gear oil in that housing can leak down the drive shaft tunnel down to the differential, if it empties out or you don't the proper amount like if it was overfilled when it was put back on it can pressure up and force that seal out so it may be dry as well, so check the levels. are you sure that the drive gear is tourqued properly as well. that could cause noises as well.
