Removing Baffle on Jardine 4-to-2
- KZBobber
29 Apr 2009 19:02 #286375
by KZBobber
Removing Baffle on Jardine 4-to-2 was created by KZBobber
I ride a KZ1000 LTD with the stock Jardine 4-to-2 and am thinking about removing the baffles.
1. Has anyone done this and how does it sound?
2. Too loud once removed?
3. What is the easiest way to remove these baffles?
Thanks
Thanks
- PLUMMEN
- Thank you received: 104
29 Apr 2009 19:06 #286378
by PLUMMEN
Replied by PLUMMEN on topic Removing Baffle on Jardine 4-to-2
the baffles are tack welded from what i remember
- KZBobber
30 Apr 2009 15:55 #286577
by KZBobber
Replied by KZBobber on topic Removing Baffle on Jardine 4-to-2
Thank you Plummen.
Anyone else removed these before?
- Thank you received: 2098
30 Apr 2009 17:36 #286613
by Patton
Replied by Patton on topic Removing Baffle on Jardine 4-to-2
Removed baffles from oem KZ900-B1 LDT (4>2) bell tip mufflers, and it was just too loud, a raunchy headache inducing loud :pinch:, not the good sounding loud as heard from an open 4>1 meg.
Riding buddies hated riding anywhere close behind me. Gave them a headache too.
Perhaps the later LTD model will sound more pleasurable running oem exhaust system without the oem baffles. But I doubt it.
We know you can't not try it :laugh:, so please inform us your test results.
Good Luck!
Good Luck!
- RonKZ650
- Thank you received: 240
30 Apr 2009 19:03 #286648
by RonKZ650
Replied by RonKZ650 on topic Removing Baffle on Jardine 4-to-2
The 76-80 900LTD and 1000LTD use the exact same pipes I believe. One screw on each muffler and the baffles pull right out if I remember right. It will be more obnoxious than a Harley at this point. I have a 900LTD that the previous owner drilled holes in the baffle and that was enough to render the pipes obnoxious. It's been 11 yrs since I even looked at my 900LTD so my memory may be flawed some, but not the noise. That sticks in my mind.
- bountyhunter
- Thank you received: 337
30 Apr 2009 19:06 #286649
by bountyhunter
Replied by bountyhunter on topic Removing Baffle on Jardine 4-to-2
Out here, you would get pulled over before you could scratch your rear running straight pipes on the street.
