Ehh... Oil leak and on the spark plug
- vincentmoy
29 Apr 2009 15:42 - 29 Apr 2009 16:05 #286322
by vincentmoy
1980
KZ750 LTD
Miles: Unknown (speedo cable broke)
Ehh... Oil leak and on the spark plug was created by vincentmoy
So, as some of you may know I just got a 80 KZ750H not too long ago and had some problems.
I didn't get too much done cause I have my school.
I got some free time and had a closer look and found some oil (kinda fresh) on the left side of the carb (right side is clean).
I took the spark plug out and all of them are black.
I don't know if this 2 incidents are related to each other at all so I figure I might just throw it out here for some opinions!
Thanks!
Vincent
Thanks!
Vincent
1980
KZ750 LTD
Last edit: 29 Apr 2009 16:05 by vincentmoy.
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
29 Apr 2009 16:29 #286335
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Ehh... Oil leak and on the spark plug
Hey vince, are you sure the stuff on the side of the carb is oil? It kind of looks like residue from the left side carb leaking.....i could be wrong though. As far as the plugs go, is there any oil on them? Or are they just loaded with carbon?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
