KZ900 and APE 410 cam sprocket question.
- GRMPer
29 Apr 2009 03:34 #286154
by GRMPer
KZ900 and APE 410 cam sprocket question. was created by GRMPer
I'm pretty sure this is a stupid question, but a search didn't reveal any answers.
I'm building a mild KZ engine with APE 410 cams and when I tried to fit the sprockets onto the cams, the sprocket's center hole was too small to fit over the second lobe of the cam. I see that APE sells adjustable sprockets, but it's not said whether or not the 410 *requires* them.
Thanks for the help.
Per
LeGrand Mk18 (KZ powered)
Per
- otakar
29 Apr 2009 03:39 #286155
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic KZ900 and APE 410 cam sprocket question.
It is common practice to notch the center hole, to fit the lobe. The APE sprockets have this feature incorporated.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
- Thank you received: 10
29 Apr 2009 06:39 #286184
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic KZ900 and APE 410 cam sprocket question.
the .410 lift cams will need them for sure.
