- Thank you received: 5
j head repair
- jordan
29 Apr 2009 12:51 #286247
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic j head repair
sweet, thanks alot everyone for all the great information. And Okatar, no offense was intended at all by questioning what APE Jay said. He is a EXTREMELY knowledgeable person who i have alot of respect for. I just wanted to know if it was possible to get away with using differnt caps even though it is not the recommended way of doing it. Looks like i will be getting some aluminum stock, and seeing if i can fix up this head. I didnt see any on ebay, aybody have any ideas where cam caps can be purchased? Kaw dealership?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- otakar
29 Apr 2009 13:09 #286249
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic j head repair
They are not sold separately from the head if you buy them new from Kawasaki. You will have to wait until a set is available on eBay. I unfortunately made a similar purchase some time ago and am in the same situation with one head. I do not worry about it any more since I have bought a few 84GPZ heads since than and do not require the standard J head anymore. Just bide your time and get them when they are available on eBay.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- irishwill
- Thank you received: 6
29 Apr 2009 15:24 #286315
by irishwill
Replied by irishwill on topic j head repair
I have fixed more than a few heads like yours just by welding multiple passes...and then using a die grinder and a file to contour the fins after.
kinda like fixing a prop on an outboard.
hope this helps
hope this helps
- otakar
29 Apr 2009 17:25 #286353
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
There is a undamaged J head on eBay right now for $75 buy now. Is it worth fixing this one?
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&s...IT&item=390047866297
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
29 Apr 2009 19:16 #286380
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Hay Jordan, I hope it was you that bought that head. It was bought almost as fast as I posted the link on this thread. That head was a steel for the $75.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- jordan
29 Apr 2009 20:06 #286400
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
DAMN! i just read your post, just barely too late. THanks alot anyways for looking out for me. I appreciate it greatly. I won mine for $30, but for that price and in much better shape its definately worth it.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- brianpclarke
29 Apr 2009 20:50 #286408
by brianpclarke
- jordan
29 Apr 2009 21:10 #286409
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
someone else more knowledgeable will chime in, but basically it is the head they used on the later kz's. They can be made to fit on the early z's with a minor cam chain idler mod. Can't be certain on the valve differences. Better flow = more horsepower. There is nothing wrong with the early heads though
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- trianglelaguna
- Thank you received: 235
29 Apr 2009 21:22 #286412
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic j head repair
just a thought...i found this thread of intertest as far as the broken fin fix....then was thinking...in my work i use a pre made shape to patch a hole by cutting my shaped patch a tad large but with clean edges ,then lay it over the junk hole and re-trace my fixer piece onto the junk...then cut the hole to accept the cleaner edged patch piece....can you square the broke fin and trace the flat stock to match then cut it???good cam tutorial too...good luck...
1976 KZ900
2003 ZX12R
2007 FZ1000
- Buda
30 Apr 2009 06:49 #286492
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic j head repair
:blush: Hey Guys I bought that head I just couldnt pass it up for $75.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
