- Thank you received: 5
j head repair
- jordan
28 Apr 2009 16:25 #286036
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
j head repair was created by jordan
i just wond a j head on ebay for my drag bike build. It isnt in the best shape, but i got it really cheap. It is a bare head, which is better as i will be needing new internals anyways. It has two fairly good sized spots where the cooling fins broke off. Is it possible to fix this without the two pieces that broke off? Any ideas? Here is a pic of the two bad spots.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- BohicaBob
- Thank you received: 35
28 Apr 2009 17:08 #286043
by BohicaBob
Replied by BohicaBob on topic j head repair
I've repaired a few broken cylinder head fins on my Zs. Simply use some flat aluminum sheet of the proper thickness, cut to fit, clean the repair site and the repair piece with something like mineral spirits. Figure out a way of holding the piece in place before you mix JB Weld in a 50/50 combination and assemble the repair piece to your cylinder head. Let dry for a day or so.
How long will such a repair last? I fixed two damaged cylinder head fins on my '73 Z1-900 in 1977 after I had to abandon my Z1 on US 101 in San Luis Obispo, CA one afternoon - okay, me fall down. Those fin repairs are still just fine.
In fact, you can repair it so well that many folks will not even notice the non-OEM fin piece(s) .
- jordan
28 Apr 2009 18:23 #286069
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic j head repair
wow, thanks alot for the help. Where can aluminum like this be purchased at?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- Thank you received: 104
28 Apr 2009 18:35 #286075
by PLUMMEN
Replied by PLUMMEN on topic j head repair
ive got some busted up kzheads i save to chop fins off of but aint got no extra j heads im ready to take the grinder to yet
- APE Jay
- Banned
- Thank you received: 58
29 Apr 2009 00:54 #286144
by APE Jay
Replied by APE Jay on topic j head repair
Did you get the cam caps? If not, don't waste any time fixing fins.
- jordan
29 Apr 2009 01:23 #286147
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
why? are they hard to come by?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- kaw74z1
- 0 to 60 in 15 minutes.
29 Apr 2009 01:34 - 29 Apr 2009 01:37 #286148
by kaw74z1
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Replied by kaw74z1 on topic j head repair
No there not all that hard to get. But I think what Jay is saying is that when the head is built is the cam caps are bolted on and the the bores are aligned bored. So if you put caps on the head that were not matched your cam bearings will wear quickly, I have seen this done on drag motors where the cam bearings are changed often But for a rider I wouldn't recommend it.
Last edit: 29 Apr 2009 01:37 by kaw74z1.
- jordan
29 Apr 2009 02:29 #286150
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Really? that seems odd that all the kz builds are using cam caps that came with their head. Especially since most of the heads that are sold on ebay dont even come with the cam caps. I have sold two early kz1000 heads myself that i did not have caps for.
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- otakar
29 Apr 2009 03:50 #286156
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic j head repair
What Jay said is rudimentary knowledge. Same as Con-rod big ends, or Crank-shaft mains. If you question APE Jay, why ask the question at all. I've been doing this from 1978, and knew this from the very beginning. Why do you think that Kawasaki goes even so far as numbers each cap individually, so they don't get rearranged, and get placed on the same journal as they were honed.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- larrycavan
- Visitor
29 Apr 2009 05:21 - 29 Apr 2009 05:24 #286163
by larrycavan
Replied by larrycavan on topic j head repair
2 more cents
Actually....it's very probable that cam caps from another head will work on that one. Guys run 'em like that every weekend.
The thing to watch out for is too tight of a clearance. All the bearings are the "same size" when new.
Get some caps, clean & lube the cams and the bearings, bolt the cams in and see how they spin. If it's tight, wet sand the bearings until the cams spin freely.
You can make yourself a hone out of some round stock that will use wet paper if you want to or you can just sand them with your finger.
If they're a little loose, the cams may walk a bit at idle and make a little noise. Who cares.....How long are you idling your drag bike
Is this the Kawasaki OEM Service Manual way....No. Then again, most people wouldn't believe some of the "non public" fixes that used to come from the Kawasaki Hot Line when you called them up about a problem...
I never assemble a motor with new cams without first spinning them in the head to see how they "really" fit. NEVER trust any aftermarket part to be correct! I've had brand new cams that were sent back because they were NFG right out of the box.....
JMO
Larry C
JMO
Larry C
Last edit: 29 Apr 2009 05:24 by larrycavan.
- Thank you received: 797
29 Apr 2009 06:13 #286177
by 531blackbanshee
Replied by 531blackbanshee on topic j head repair
great info,thanks for the input.
leon holmes
leon holmes
- Jack
29 Apr 2009 12:17 - 29 Apr 2009 12:28 #286244
by Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Replied by Jack on topic j head repair
Fixing broken fins isn't that tough. Done the JB Weld repair and also had a skilled welder fix heads in the past.Finding flat aluminum stock shouldn't be that hard and it's easy to work with to get the repair piece you need.
I concur with Larry C. - My experience in 35 years of owning Z's and about 30 years of dragracing, & that of many other people as well ,is that the caps from one head can be used on another. I know Mother K says not to do this but I can show you many motors with replaced cam caps.
I wasn't about to throw out my big$$ GPZ head when the cam chain broke at the top of 1st.gear and took out a couple of caps and broke the cams into 12 pieces NB. His advice to check for tight fit is the most important point to note.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Last edit: 29 Apr 2009 12:28 by Jack.
