- Thank you received: 5
Central Ohio experienced mechanic?
- Gman
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- Zacknhs
Columbus, Ohio
Go Bucks
1978 Kz1000 <- first bike and i love it!!
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- Thank you received: 2098
My brother's '76 kz900 engine has a strange ocsilating (sp?) noise that we can't diagnose. Sort of like a chain with a tight spot or a mis-matched gear set. Bike only has 8,000 original miles. I had the head off and replace the front cam chain idler gear because it had separated. Everything else looks like new. Noise is still there. I don't want to take it apart again if I don't have some idea what to look for. If anyone knows of a knowledgable mechanic in cental Ohio that could listen to it, that would be helpful. If I can't find anyone, I may bring it to Mid-Ohio for a listen. Thanks for any suggestions.
With a little more information about the noise, perhaps we could help diagnose its source.
Such as, is the noise evident when the bike isn't moving and with transmission in neutral?
For example, some mysterious things can result from a kinking drive chain.
Good Luck!
- Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Remove points cover.
Crank and warm-up engine.
Use 17mm "nut" to hand turn crankshaft clockwise in normal direction of rotation. (Never use 13mm bolt head from end of crankshaft).
Stop turning exactly when T mark aligns with case mark. Never go backward. If go too far, repeat again clockwise and keep doing it over and over if necessary until getting it to stop exactly when T mark aligns with case mark.
The alignment of T mark without bypassing case mark is easier to achieve with sparkplugs removed.
The TDC top-dead-center position puts rear of cam chain in its slackest position, where the adjuster can exercise maximum effect.
Loosen locknut on the adjuster.
Loosen bolt on the adjuster. (It automatically removes slack per design specs).
Don't "kick over" the motor, as that will likely undo what you've just accomplished.
Tighten bolt (snug -- not Godzilla).
Tighten locknut (snug -- not Godzilla).
Re-attach points cover.
Replace sparkplugs if they were removed.
Given the very low mileage, I would think the camchain and adjuster to still be in good condition.
Good Luck!
