exhaust half collars.
- brianrae33
26 Apr 2009 04:56 #285346
by brianrae33
1982 kz1000ltd
exhaust half collars. was created by brianrae33
anyone know what year half collars i could possibly use for a v&h pips on an 82 kz1000 ltd..the stock ones which i have new are to short...i was thinking maybe ones from a 78??thanx for any info..
1982 kz1000ltd
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
26 Apr 2009 06:00 - 26 Apr 2009 06:01 #285354
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic exhaust half collars.
I'm not 100% sure on the 1000's but I do know that around 81 on the 650's and 750's Kaw started welding a piece that is about 1/2" long on the ends of the stock exhaust systems. This required half collars that were shorter than the earlier bikes. I'd say you are most likely correct that collars from an earlier 1000 would solve your problem.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Last edit: 26 Apr 2009 06:01 by The Gringo.
- brianrae33
26 Apr 2009 07:27 #285368
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic exhaust half collars.
yeah...that's kinda what i figured..now if i can find a used set with out having to order from mah kaw again...took two weeks for these to get in..and i'm on vacation in a week...
1982 kz1000ltd
- DoubleDub
- Visitor
26 Apr 2009 08:15 #285379
by DoubleDub
Replied by DoubleDub on topic exhaust half collars.
How short are they? You might be able to double up on exhaust gaskets to fill the space or get a thicker gasket. I know the ones on my Kz900 aren't very thick and Z1E mentions that some aftermarket exhausts require thicker gaskets to seal.
I'll find the link and post it.
- DoubleDub
- Visitor
26 Apr 2009 08:17 #285380
by DoubleDub
Here it is - again this was for my Kz900 (and I don't know the manufacturer of my pipes), not positive about the 1000 or even how short you are.
www.z1enterprises.com/detail.aspx?ID=196
- Tony
- Thank you received: 13
26 Apr 2009 09:02 #285384
by Tony
Replied by Tony on topic exhaust half collars.
- keith1
- Thank you received: 2
26 Apr 2009 15:55 #285455
by keith1
Replied by keith1 on topic exhaust half collars.
DoubleDub wrote:
i d call jeff at z-1........
