slotted cam gears or stretched chain
  • alittlezzzz
  • alittlezzzz's Avatar Topic Author
05 Mar 2006 17:51
#28530
hello
im in the process of checking my vavle clearance and noticed my intake and exhaust marks are off 1/32 intake is low and exhaust is high when im at tdc. ive checked tdc with a indicator in the sparkplug hole and is correct on 1 and 4 or maybe alittle off but off in the same spot from the t mark. so is my chain maybe stretched or do i need to slot my cam gear. :S
  • wireman
  • wireman's Avatar
Re: slotted cam gears or stretched chain
05 Mar 2006 17:59
#28533
measure links;)
  • alittlezzzz
05 Mar 2006 19:48
#28582
i have counted the links and have 36 dots on the chain up 1 from the ex mark to the intake mark. what would i measure from roller to roller i dont have a spec in the book for that and i dont have new chain to compare it too.:S a do you think the chain is stretched then.
  • wireman
  • wireman's Avatar
05 Mar 2006 19:55
#28584
on kz1000 its 155.48-155..71 standard and 157.8mm max for 20 links stretched out.somebody on here should have a 650 shop manual with the limits.;) goodluck,happy wrenching!
  • BSKZ650
  • BSKZ650's Avatar
06 Mar 2006 04:59
#28642
my 650 book says---- service limit 128.9mm at 20 links
then turn and fire!!!
77 ltd1000, current rider
76 kz900, just waiting
  • alittlezzzz
06 Mar 2006 16:58
#28791
so its a solid chain i need to ruin the chain to measure it so i think i shall leave it alone for now unless you guys have any suggestion thanks later
  • wireman
  • wireman's Avatar
06 Mar 2006 17:10
#28798
ruin it?:whistle:
  • steell
  • steell's Avatar
06 Mar 2006 18:42
#28845
wireman wrote:
ruin it?:whistle:
My question as well.
Why would you have to ruin it just to measure the distance between twenty links? Just measure across the top.
  • DanOz7Five0
  • DanOz7Five0's Avatar
06 Mar 2006 18:53
#28859
steell wrote:
wireman wrote:
ruin it?:whistle:
I didnt understand at first either. Take the top roller off your head and you should be able to measure out the links. Ignore the arrow in this pic, but the top roller is just to the right of my finger.
  • rammy
  • rammy's Avatar
07 Mar 2006 06:59
#28973
I just went through all that last week.Looks like you rolled the crank shaft backwards and that is were all the slop in the cam chain came from.It took me a couple of tries to get the cams back in time but you have to be patient.I kept the chain tight from the exhaust cam to the crank and worked back to the intake cam.Make sure you have the 36 link count and contuine on with your assenbly. Good luck
The barn yard;77 Kz650B-1 Kaw(the fun one) & 89 classic hog.
Chicago area-south burbs
  • alittlezzzz
08 Mar 2006 16:41
#29462
is this were you should measure from ( )( )( )
imeasured two like this and got 47.625mm
and two like this and got 31.496mm
47.625 times 2=95.25
31.496 times 2=62.992
add=158.242
ya like my picture lol but im outa spec maybe:side:
  • alittlezzzz
08 Mar 2006 16:44
#29463
my picture didnt turn out thats supposed to be the chain and arrows moved maybe you will understand. the arrows were under the ( on each end.
