- Thank you received: 6
Different Engine Knock
- grumpy56
25 Apr 2009 06:36 #285134
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Different Engine Knock was created by grumpy56
Morning. J2 engine runs great and no unusual noises anytime EXCEPT, when cold and am on 1/2 choke and it is barely at 1K RPM, the engine knocks like crazy. Rev it up and its OK. Should I kcik up my idle? Any other suggestions? Thank you.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- Thank you received: 2098
25 Apr 2009 06:47 - 25 Apr 2009 06:51 #285135
by Patton
Replied by Patton on topic Different Engine Knock
If not already done, adjusting camchain tension plus good carb sync will reduce a crunchy idle.
But when cold and on 1/2 choke at 1000 rpm, the engine is likely struggling regardless of other settings.
Good Luck!
Good Luck!
Last edit: 25 Apr 2009 06:51 by Patton.
- grumpy56
25 Apr 2009 07:38 #285137
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Replied by grumpy56 on topic Different Engine Knock
Thanks Patton. I have an auto adjuster for the cam chain plus as far as I know my carbs are properly synched. My best bet might be just to give it a bit of throttle when warming up to avoid the sounds of pain.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- gnfreak
25 Apr 2009 07:51 #285140
by gnfreak
Normal, IL
1980 KZ1000-G1 Classic - Sold
Replied by gnfreak on topic Different Engine Knock
primary chain knock? i get that at times, sometimes its pretty loud. i was told to keep the idle at 1500 and it goes away. once the bike is warm i dont have the noise at all. really freaked me out when i bought it last fall.
Normal, IL
- grumpy56
25 Apr 2009 08:48 #285155
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
that sounds like it is the same as mine gnfreak...don't like it one bit
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- donthekawguy
- Thank you received: 8
25 Apr 2009 12:29 #285176
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Different Engine Knock
Did you recently put in 20/50 oil? If so get it out and use 10/40. Mine and few other people in here used 20/50 and all of our bikes knocked until we changed it out.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
25 Apr 2009 12:31 #285177
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Different Engine Knock
ya i had the same thing happen to me when i put in 20w-50, it knocked really bad, but i put in the 10w-40, and all is well now.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- grumpy56
25 Apr 2009 12:47 #285179
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
have 20-50 in mine, but it sounds like I need to go the thinner variety
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- timebomb33
- Thank you received: 10
25 Apr 2009 13:06 #285182
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Different Engine Knock
keep either 20/50 in it or 10-40 no less and for every body that does not know the big kz's don't have a primary drive chain they use gearsone on the crank one on the basket the noise you are hearing is excess backlash in the primary drive gears it happens to alot of bikes when first fired and they are having a tough time trying to figure out wether they want to run or not sometimes it can be lessend by a proper carb sync or by leaving the enrichner [choke ]on a bit longer or by upping the rpm a bit at idle not a big issue guy's as long as it goes away after it warms up. in the heat of the summer definitly use 20-50 and change it more often then normal, oil is cheap engines are expensive.
- grumpy56
25 Apr 2009 19:32 #285254
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Appreciate the info. Started it old today and just kept the RPMs up a little for about 30 seconds and I didn't notice the dreaded knock.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
