Problem! Engine Knocking
- KZBobber
I do not know if the carbs need adjusted now that the wrap is on or what. It is pretty violent.
Has this ever happened to anyone? Any suggestions are helpful.
- Pro_window78
- KZBobber
The wrap is not in the connection. I believe there could be a slight exhaust leak. How is this fixed?
Thanks
- bountyhunter
- Thank you received: 337
Exhaust gaskets are hollow copper donuts that crush when you tighten the pipes down. They must be replaced each time you take the pipes loose or they will leak like a real mutha. I think Z1 sells the gasket rings.Yes I did replace the exhaust gaskets, but they dont seem to be in the best shape.
Thanks
- KZBobber
- bountyhunter
Yes. When mine leak at the head pipe, they make a loud "crack-crack-crack" kind of sound that gets louder the more I open the throttle.Thank you bounty. Would this cause the engine to knock or sound like air is popping out of it?
- KZBobber
- bountyhunter
I'm sure you can get them at a Kawi dealer, but they might gouge you. You could check around at the local bike shops if you have any nearby.That must be it. Thanks again. Do you know where you get these gaskets? or do you have to order them online?
If you decide to order them from Z1:
www.z1enterprises.com/detail.aspx?ID=196
They usually ship things very fast. With small items they have in stock, they usually get them to me in maybe four days. When I buy these, I get a bunch of them so I have some around in case I need them.
- nads.com
- Thank you received: 20
It's up to no good! If it keeps knocking call the cops. You can get a restraining order.Last night I wrapped my headers with exhaust wrap and now once I have re-applied my exhaust, my engine seems to be knocking where the headers meet the engine. This is on a 1980 KZ1000 LTD.
- OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
