1977 kz 650 upgrade
- KAWMAN74
24 Apr 2009 12:05 #284814
by KAWMAN74
1977 kz 650 upgrade was created by KAWMAN74
Hi i was wondering if any one could give me some info ?
I have a 77 kz 650 and i wanted to get some more power out of it.
I allready added jet kit and air pods and kerker header but i have a 1981 kz 750 engine in the garage that needs pistons .
I was wondering if that engine would work in my bike ?
If so i would like to go with a bore kit for that before i install it .
What ize cams do i use ?
what size pistons ?
what valves to use ?
and also what else can i do to get more h.p.
thanks for any and all help on this .
what size pistons ?
- Mark Wing
- Thank you received: 22
24 Apr 2009 12:47 #284827
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic 1977 kz 650 upgrade
Welcome to KZR. Sure the 750 engina will work in the 650 frame. You may have to play with the motor mounts a little. I think the 750 is rubber mounted.
Gpz cams work good.
An 810 kit should do
The valves are OK, maybe a valve job.
Clean up the ports a little.
Mark
Gpz cams work good.
Mark
Yorba Linda Cal.
- KawiConvert
- Thank you received: 4
24 Apr 2009 12:50 #284829
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic 1977 kz 650 upgrade
kzzone.com/
Go there and open your wallet. You'll get more power and a better hp/weight ratio with your money gone :laugh: . Ok, so its expensive, but if you want more power you'll have to pay one way or another.
- lapeerray
24 Apr 2009 14:57 #284857
by lapeerray
78kz650b2, 2009 kawasaki 25 hp Oturn John Deere with a 62" cut I had to have it. It was green and was powered by KAWI...,78 yamaha golfcar, Gone but not forgoten 82 v65 magna, 89 1200 Vmax, 72 GS380GT mint with 2000m.grandfather baught brand new in 72
Replied by lapeerray on topic 1977 kz 650 upgrade
Come on we want somthin for free:silly:
- KawiConvert
26 Apr 2009 00:32 #285323
by KawiConvert
Cut off what you don't need on the bike, loose 20lbs of winter insulation. That'll do wonders to the performance and its free (other than 5.40 for the cut off wheels).
