Bike jumps when put into first
- fireworks
24 Apr 2009 10:04 #284781
by fireworks
Bike jumps when put into first was created by fireworks
Hi,
I'm looking at a KZ that has just had the clutch cable changed. It jumps when put into gear.
I don't know if this was happening previously.
Just an adjustment needed? Is there something I should be looking for?
- timebomb33
- Thank you received: 10
24 Apr 2009 10:14 #284785
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Bike jumps when put into first
yes the clutch cable or main adjuster will need to be adusted.try to find a manual it will show you the procedures involved there are 3 different adjustment points. two on the cable one on the motor the one on the motor is the main adjustment point, the cable adjustment are for fine adjustments at the lever you will need about an 1/8" free play .
- fireworks
24 Apr 2009 15:24 #284864
by fireworks
Replied by fireworks on topic Bike jumps when put into first
Perfect I assume that all adjusters should mid range normally?
- gane
24 Apr 2009 17:54 #284902
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Bike jumps when put into first
Fireworks, Uh no. The manual explains best.the 1st adjustment is the clutch ramp/rod which is turn in til contact then backed off @ 1/4 turn then locked. 2nd is at cl lever adjuster, and can be set to center if desired, 3rd, adjust cable center adjuster to give @ 1/8 inch freeplay at lever. this one will vary with cl. plate wear & type. this should give a normal feeling lever. It's not uncommon for bike which have been sitting to lurch/bang when 1st put in gear, as plates tend to stick until broken free and recieve lubrication, hope this helps.G
- timebomb33
24 Apr 2009 17:56 #284904
by timebomb33
could not have said that better my self sir beautiful.
