New exhaust system... exhaust leaks.
  • Alex_KZ1K
  • Alex_KZ1K's Avatar Topic Author
05 Mar 2006 13:59
#28444
Ok, I want to start by saying I'm an idiot. With that said, I'll tell you why I have exhaust leaks. I installed my MAC 4-1 system today using the metal exhaust holders that the system came with and new o-rings. I don't know if the metal holders were the wrong depth or something, but I ended up snapping 3 out of 4 flanges before the nuts were even seated. I don't even know what the hell happened... Would that happen if I put the left sides on the right or something? :blush:
  • steell
  • steell's Avatar
Re: New exhaust system... exhaust leaks.
05 Mar 2006 14:34
#28459
Are you talking about the half moon shaped keepers?
I have not installed a MAC on a four cylinder but on the 750 twins the MAC does not use those. If the flanges are welded to the pipes, then there is no need for those collars, they are only used when the flanges slide on the pipes.
  • Alex_KZ1K
05 Mar 2006 17:34
#28525
Yeah, I definitly need those collars, I just think they may have been the wrong length or something...
  • bluegill
  • bluegill's Avatar
05 Mar 2006 18:10
#28536
Don't know about your bike, but here's how the MAC 4-1 goes on my 4cyl 750E1. No collars. Ignore the rusty bolts, now replaced.
I remember having trouble getting the exhaust seated correctly. I had to do it a couple of times due to leaks and my paranoia about breaking a stud, but it's solid now. The pipes have to be aligned just right.
  • 77KZ650
  • 77KZ650's Avatar
05 Mar 2006 18:11
#28537
I'll get some pics of my MAC 4-1, it didnt use any of the stock stuff either
Scott
Post edited by: 77KZ650, at: 2006/03/05 21:13
07 MDP Rookie of the Year
  • Alex_KZ1K
06 Mar 2006 05:27
#28647
My flanges, the ones that broke, were the originals (the steel with fins type). I ordered a set of 4 flat aluminum flanges from Z1E yesterday. I'll try without the collars and see what happens.
