Timing - How do you reset the timing on a bike?
- KOOL RYDER
- KZ 650B2 / KZ 1000E
21 Apr 2009 12:30 #283713
by KOOL RYDER
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
Timing - How do you reset the timing on a bike? was created by KOOL RYDER
Hey guys,
How do you reset the timing on a KZ 650?
The last time I had it in the garage it cost a pile of loot and the guy said,"your timing is advanced?"
What did he mean by that, and what would be required to set it back to spec?
If you couldn't tell I am as green as my avitars a#s.
1978 KZ650B
1979 KZ1000ST
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
21 Apr 2009 13:58 #283732
by hardr0ck68
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
Replied by hardr0ck68 on topic Timing - How do you reset the timing on a bike?
It is very easy to do with an electronic ignition, but I can't help you with the factory points set up.
Doing it yourself will only cost you the cost of a timing gun (some as cheap as $20, but more likely a decent one will run you $60-100... but hell its a tool, so buy it use it and have it till you die....)
If you still have a points ignition this may be a good time to upgrade to either a used factory set up, or a dyna set up.
1977 kz650 c1
- dshelly
- Thank you received: 5
21 Apr 2009 14:02 #283734
by dshelly
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Replied by dshelly on topic Timing - How do you reset the timing on a bike?
Buy a manual, and read up. they are cheap and will save you a ton if you have any mechanical ability at all. The factory ones are the best ,in my opinion.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- timebomb33
- Thank you received: 10
21 Apr 2009 14:14 #283736
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Timing - How do you reset the timing on a bike?
you will need a timing light to start with for sure after that we can give you a hand.
- gane
21 Apr 2009 19:44 #283906
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Timing - How do you reset the timing on a bike?
Perhaps a good question would be, cam timing or ign, timing. if you spent a boodle, and valve shims were changed, a worn cam chain might come closer to spec by advancing exhaust cam a pin and timing intake to match. conversly worn points blocks usually require retarding plate to aquire proper timing. luck g
