valves
- KZ700A1
20 Apr 2009 14:51 #283383
by KZ700A1
1984 KZ700A1
1982 GS550L (the L is for lady!)
Life's a garden.....dig it
valves was created by KZ700A1
So over the winter I got the valves on my 700 all set right & replaced the gasket, everything was great. I changed the oil & have run it a few times (less than 500mi) this year and the tap started to come back, now Saturday the bike fell over while running (no real damage) and now the tap is even worse. Could the falling over have knocked something out of whack? Where should I go from here?
1984 KZ700A1
- RonKZ650
- Thank you received: 240
20 Apr 2009 14:58 #283386
by RonKZ650
Replied by RonKZ650 on topic valves
Exhaust leak most likely at the head.
- KZ700A1
20 Apr 2009 15:05 #283390
by KZ700A1
1984 KZ700A1
Replied by KZ700A1 on topic valves
Thanks, I'll take a look.
1984 KZ700A1
- gane
- Thank you received: 1
20 Apr 2009 15:06 #283391
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic valves
KZ, silly thought, but listen/feel for a possible exhaust leak. Tapping (to my ear)can be , 1 valves, wristpin/bigend (usually flutter or knock) piston slap. exhaust leaks can exibit in many forms. hope for the best. a casual tip over shouldn't cause any internal damage/change.. Luck G
- KZ700A1
20 Apr 2009 15:23 #283394
by KZ700A1
1984 KZ700A1
The motor has always had a knock to it, I didn't think anything of it b/c I've never really heard an old Kaw 4cyl and wasnt sure if its inherent to the motor or not.
1984 KZ700A1
- gane
20 Apr 2009 16:14 #283408
by gane
KZ, Engine noises are a constant. evaluating them much more specialized. new zeds were at one time almost sewing machine smooth. period yamahas made a cam chain whiz which overpowered their exhaust. SOHC hondas made so much primary chain noise it sounded like they were coming apart at idle.(almost as bad as dry cluth Ducks) If concerned see if there's an old fart willing to lend an ear. Period KZ's were/are stout.30+ years of wear/sitting means they are no longer silent. noises which change/increase should be evaluated. light to moderate engine noises which decrease w/ warming accepted as par. I hope this helps.G
- BSKZ650
- Thank you received: 14
21 Apr 2009 08:17 #283642
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic valves
did you sync the carbs, they may be out of balance causein the cyls to pulse and making the cam chain rattle
- KZ700A1
21 Apr 2009 17:27 #283829
by KZ700A1
1984 KZ700A1
I havent synched the carbs yet, but the tappping usually goes away after about 2k RPM. Will an inexpensive synch tool work, or should I buy the pricey one?
1984 KZ700A1
- BSKZ650
22 Apr 2009 06:57 #284016
by BSKZ650
I have the mercury stick type, but I dont think you can buy them anymore.
like with all tools, you buy cheap you get cheap
