Hi Z owners, i still have the problem of oil leaking at the pipe (16109-003) behind the cylinders. I already renewed the 18mm O rings and everything at the pipe and the block looks smooth , no scrathings. Does somebody know if there are thikker 18mm O rings or knowing an other solution for this problem?
Willem
