Running on bad rings
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
19 Apr 2009 22:41 #283256
by thadley55
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
Running on bad rings was created by thadley55
I have a 76 KZ900 and last year I did a diagnostic to see if the rings were bad and sure enough they are. So would it hurt the bike to run on bad rings for a season? I have heard things about dropping valves or over compressing them or something? What is this and is it a danger?
ThanxB)
ThanxB)
- bountyhunter
- Thank you received: 337
19 Apr 2009 23:33 - 19 Apr 2009 23:34 #283264
by bountyhunter
Replied by bountyhunter on topic Running on bad rings
If the hot compression is within service manual specs, you can run it.
Last edit: 19 Apr 2009 23:34 by bountyhunter.
- thadley55
20 Apr 2009 06:45 #283284
by thadley55
Replied by thadley55 on topic Running on bad rings
Thanks for the advice, where in the service manual would I find those numbers? I looked in the index but didn't find compression anywhere, don't see it on the spec sheet, and I can't find it posted near ring replacement? Maybe I overlooked it but it is always good to get advice from someone who has put their eyes on it already.
ThanxB)
ThanxB)
- bountyhunter
20 Apr 2009 14:21 #283373
by bountyhunter
In my 750 twin FSM, it is in the chapter called "Maintenance-Engine". For mine, the nominal compression is 156psi and service limit is 115 psi.
- thadley55
20 Apr 2009 21:16 #283508
by thadley55
I'll check it out thanksB)
- timebomb33
- Thank you received: 10
20 Apr 2009 22:55 - 20 Apr 2009 22:56 #283535
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Running on bad rings
is the engine smoking badly if it's not run it and keep a good eye on your oil consumption if it goes up drasticly then park it. by the way how did you figure that you had bad rings.
Last edit: 20 Apr 2009 22:56 by timebomb33.
- roy-b-boy-b
- Thank you received: 103
21 Apr 2009 02:21 #283584
by roy-b-boy-b
Replied by roy-b-boy-b on topic Running on bad rings
I would get a bottle of ring free from your local yamaha shop and give it a couple of treatments and that will tell you if the rings are stuck. I use this product on a lot of machines that have been sitting. Great product.
It will clean up your upper engine. Be sure to change the oil after the shock treatment. Roy
- donthekawguy
- Thank you received: 8
21 Apr 2009 03:43 #283591
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Running on bad rings
Once the compression gets below 115-120 you will start having plug founling problems. Mine was down to 110 in all four and I would foul plugs no matter how lean in about an hour of riding.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Old Man Rock
- Thank you received: 225
21 Apr 2009 04:09 #283597
by Old Man Rock
Smoking, pinging/ringing sound (broken rings) in one or all cylinders, fouled plugs, no running power, metal shavings in oil, extremely low compression measurements etc....
Compression test for sure and if possible leak down test.
Me personally, if the rings are truly damaged, why the hell would you run this old girl is beyond me. :blink:
Example, pinging/ringing sounds in the cylinders normally equates to broken rings. These rings start busting up in your cylinders and shread the cylinder walls (sleeves) kiss the cylinder goodbye... Time for a bore job, most probably sleeves as well. Then there's the damage to the pistons/head/valves...
Now because you just wanted to ride the summer you're out a couple of grand in repairs... :ohmy:
Now you have metal shavings in your lower end so now you have to split the cases to get them out... See where this is going?
All in all, just not worth it... Or is it... Follow the others guidance, test if truly damaged, open her up, visually inspect the cylinder walls, measure the ring end gaps, find out if they're broken, inspect your pistons etc...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Running on bad rings
... I'm with TB on this, was wondering the same...by the way how did you figure that you had bad rings.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- thadley55
22 Apr 2009 09:08 #284037
by thadley55
I did the water test on the pipes and found I had a dead cyl, after I checked valve clearances I did a comp. test ad had low compression. Then to check and see if it was rings or valves I poured a teaspoon of oil down the cyl. and sure enough the numbers went up drastically. These were all things I posted last year, thanks for all the good advice. I have decided to take the plunge and do them. I am going to start a new thread asking if there are any KZR's in DFW. I need to know a respectable shop around here that will take care of me. I need head work and the cans checked and honed. ThanxB)
