Problems shifting into 2nd
- mkeating
16 Apr 2009 09:56 #282254
by mkeating
Problems shifting into 2nd was created by mkeating
Hi all,
New member looking for some help on fixing my 81 Kawi 440 ltd. I fired it up the other day and took it for a rip and ran into some new problems. Previously when I used to shift into second, the bike would occasionaly "pop" out of second into neutral, and I would have to click up hard on the clutch to get it to pop back into second. When I took it for a drive the other day, it was having a very hard time shifting into second. I would click up on the clutch several times, and I could hear it "rattling" as if it wasn't catching. Eventually after many tries it would catch into second, and then I wouldn't have any problems from there shifting into 3rd, 4th and 5th. Does anyone have any suggestions on what may be causing this? Thanks!
- PLUMMEN
- Thank you received: 104
16 Apr 2009 10:02 #282259
by PLUMMEN
Replied by PLUMMEN on topic Problems shifting into 2nd
look under youroutput shaft cover on the 900-1000s anyway once you remove front sprocket and cover under it there is shifter linkage under there that sometimes needs a little tlc.
- timebomb33
16 Apr 2009 10:07 #282264
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Problems shifting into 2nd
engaugement dogs on the gears or possibly bent shift fork also check to see if your shifter is loose that can cause shifting issues as well also what are you using for oil use a motorcycle specific oil and it may help.and what you refer to as the clutch is actually the shifter the clutch is on the left side handlebar.just so it won't cause any confusion in the future. by the way welcome to the site also you may have a problem with the cable adjustment at the clutch lever you need to have about an 1/8" of freeplay there.
- gane
18 Apr 2009 15:27 #282885
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Problems shifting into 2nd
M, This may or may not be of use, I'm not familiar with your' bike, but...poor shifting, popping out of gear is usually an indication of worn shift forks/gear dogs/or shaft location. Many trans counter shafts are held in position by the c/s sprocket nut which draws counter shaft into proper position. a quick and cheep place to start. luck G
- boots
19 Apr 2009 13:21 #283109
by boots
present bikes 1976 KZ900, 1978 KZ650 Past bikes Too many to remember!!Mostly Kawasakis and a few Sportsters
81 cb650
Replied by boots on topic Problems shifting into 2nd
I had the same prob. with my 74 z1 900 2nd gear shifting fork was bent!! GOOD LUCK! Easy fix!
Later,Boots
Later,Boots
81 cb650
- mkeating
20 Apr 2009 07:59 #283301
by mkeating
Replied by mkeating on topic Problems shifting into 2nd
Thanks to all for the great replies, I will start disecting the problem as soon as I get a free weekend here! Cheers,
Mat
Mat
