Exhaust studs
  • Jeff.Saunders
  • Jeff.Saunders's Avatar Topic Author
  • Vendor
Exhaust studs
04 Mar 2006 15:41
#28220
I learned something new about exhaust studs recently when a customer questioned why he could not thread a nut on one end of a stud.
Although the thread on both ends of a Z1/KZ900 exhaust studs is 6mm and both ends are the same thread pitch, the threads are NOT the same. The end that threads into the engine has a slightly larger diameter (2-3 thousandths of an inch) thread to ensure they hold tighter in the aluminum head. I checked some other diameter studs and found the same thing.
It makes sense given the different expansion rates of metal.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • wireman
  • wireman's Avatar
Re: Exhaust studs
04 Mar 2006 15:47
#28227
correct!;) but loctite helps;)
