cam id
- judgie
only makeings i can see on them is "joy 2" and thats engraved on the shaft.
will have to wait till its built up to mesure lift etc but you can see the differance over stock ones
cheers rob
forever tweeking aircooled engines, well it is my job
77 z650c1
- judgie
uk based company but there dont do them any more.
it has .375 lift on a 105 lobe centers so a big cam for the 650
just need to find some valve springs now and poss some shim on top buckets.
77 z650c1
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- APE Jay
- Banned
- Thank you received: 58
go to ape and you already have shim under bucket set-up ape has some of the best valvetrain components.
Guy you are fast, beat me to it kzzone.com/cams.html
- judgie
he described the cam as full race in a 650 as it was designed as a fast road/race cam for the 1100, but that dont mean anything in my book.
i'll get it in and set up, see if i need to clerance anything. any idea on what springs i'm going to need?
cheers rob
77 z650c1
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- judgie
77 z650c1
- loudhvx
- Thank you received: 1616
dont think I have ever seen a over bucket shim for the 650 motor
That raises a question. If you can put a shim-under setup from a 650 into a 900, can you put a shim-over setup from a 900 into a 650?
Anyone done this just for easier shim maintenance?
Don't mean to highjack this thread... just curious.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Maybe, but why would you want to add 25%-30% more weight, to your valve train?
- larrycavan
- Visitor
Ran that way for many miles....
- loudhvx
Definitely not a peformance improvement, but some just use a bike for basic transportation. I could see it making routine maintenance a lot easier, plus no chance of stripping cam bearing caps.
1981 KZ550 D1 gpz.
Other links.
- APE Jay
- Banned
You can run 900 sot setuo in a 650
The springs you need are #VS900K kzzone.com/cams.html
