Welded crank question
- dman3998
15 Apr 2009 17:30 #282077
by dman3998
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
Welded crank question was created by dman3998
After the crank is welded, there is NO changing of the rods correct?
So do you put in new rods before you weld or is that not a big deal.
Or is the real question for regular normal street/highway cruising is it not any advantage to weld the crank anyway.
just trying to add to the knowledge base in the old noodle.
Dman
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- timebomb33
- Thank you received: 10
15 Apr 2009 18:16 #282090
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Welded crank question
stock kawi rods and bearings are really tough if your building a hotrod street bike or a small inch dragb ike the normal procedure is to make sure the crank is true the roods bearings are in good shape then you weld the pins to the flywheels so the crank can not twist under heavy loads if you need to replace a rod or bearing you just grind the weld down and press the crank apart normally unless your going to a big inch dragbike you just weld up the stock crank that came in your engine and go have fun.
- RonKZ650
- Thank you received: 240
15 Apr 2009 18:52 #282098
by RonKZ650
Replied by RonKZ650 on topic Welded crank question
You mean to tell me the crank is pressed together and after welding the rods cannot be unbolted. In other words no rod caps? I never knew this after 30 yrs of ownership. :laugh: No more KZ1000s for me, I'll stay with the 650s.
- StreetfighterKz
- Thank you received: 117
15 Apr 2009 18:59 #282100
by StreetfighterKz
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Replied by StreetfighterKz on topic Welded crank question
RonKZ650 wrote:
Yup, one piece rods.
Dman,
If your bike is stock and you're doing just street/highway riding with the occasional trip to the track then you don't really have a reason to weld the crank. If you have to split the cases for another reason then go ahead and have the crank welded so it'll be ready for future upgrades. Make sense?:huh:
Later, Doug
Dman,
Later, Doug
1989 Vmax
