Will these flanges fit Kz650?
- fallenknight308
- When in doubt, use a hammer!
15 Apr 2009 16:23 - 15 Apr 2009 16:26
I like the way they look, But will they fit?
If not, where can I score some for my 650?
Thanks!
www.z1enterprises.com/detail.aspx?ID=1984
Thanks!
[img=http://img9.imageshack.us/img9/4085/kz650011.th.jpg]
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
AND I KEEP ON POURING THE $ INTO IT!
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
Last edit: 15 Apr 2009 16:26 by fallenknight308.
- rstnick
Re: Will these flanges fit Kz650?
15 Apr 2009 17:59
Nice looking C2 fallenknight.
If I'm not mistaken the kz1000 has larger exhaust studs than the 650.
Some 750 flanges are different than the 650, and you can swap exhaust between them with no problem, so are the kz1000s gonna fit?
Over at KZ650info.com there are members on the forum with both 650s and 1000s. They may know.
Or some one may have a spare set of 650 flanges, gut I don't think that's what your after.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- MFolks
15 Apr 2009 18:14
The early Z1's and KZ's had 6mm studs and sometime later switched to 8mm studs for the exhaust header clamps on the 1000's and 1100's.
- kawsakiman
15 Apr 2009 19:11
no, they will not fit.
the spacing is different as you can see in the picture.
i have one set off a gpz750 i'm using but i think i have another set somewhere.
they are a little hard to come by.
keep your eyes open for the flat spot on the side.
- fallenknight308
16 Apr 2009 14:02
Thanks for the help
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
1978 KZ650 C2
K&N PODS
4-1 KERKER
WG IGNITION MOD
DYNA IGNITION
- gorack
16 Apr 2009 16:26
checkout the flanges for a 2000 zr7 the will fit and are smooth like your looking for, they will fit
