77 KZ750 twin
- cheezewhiz6
15 Apr 2009 10:38 #281975
by cheezewhiz6
77 KZ750 twin was created by cheezewhiz6
Iam new to this forum, Hello from ohio. I just aquired a 77 kz750 twin from my uncle and it runs but not past 3000 rpm. The points are brand new but i dont know if they are set right. any help or suggestions are greatly appreciated.
- MFolks
- Thank you received: 540
15 Apr 2009 12:36 #282008
by MFolks
Replied by MFolks on topic 77 KZ750 twin
This is a website covering most if not all of the Kawasaki twin engined bikes:
www.armbell.com/forum/index.php?mforum=kz400
- bountyhunter
- Thank you received: 337
15 Apr 2009 14:21 #282040
by bountyhunter
Replied by bountyhunter on topic 77 KZ750 twin
From the manual on my 79 KZ750 twin:
The point gap needs to be .012" - .016". Check timing with light: at idle, the timing mark and the "F" must align. At over 3000 RPM, the timing mark and the pair of lines align.
You should take the advancer mechanism off and clean and lube it, they are notorious for sticking.
