- Thank you received: 11
Stock Cam questions (KZ1000)
- tachrev
- Rubber Side Goes Down
1.) Are these cams the same as the Z1 cams? If so stock specs are(according to the MegaCycle catalog):
Intake 237 @ .040" .327" lift
Exhaust 229 @ .040" .296" lift
Is this correct or are the KZ1000 cams different?
2.) If they are different, does anyone know the actual lift and duration @ .040"?
3.) If they are the same, has anyone ever ran a intake cam on the exhaust side? Like this:
Exhaust 237 @ .040" .327" lift
I know I would lose my tach drive, but I am switching to an electronic tach anyway.
4.)If you have done this, how did it run?
5.)Anyone got a stock intake cam they are tired of tripping over?
I would think it would pick up a few horsepower. Obviosly not as much as some aftermarket drop-in cams, but I don't have the money for a new set and they are not common on ebay from what I've seen.
I know someone who has been racing these bikes for a while will know the answer! Thanks.
Build Thread
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- tachrev
what must be realized here in practical terms is that; the .008" of lift gained is equivalent to a standard piece of printer paper folded over once. That is the amount of extra lift you will gain. That is not even worth the postage to ship a cam. Just by removing all of the sand cast roughness, you can easily gain 5-7% in flow. That now is significant. If you really spend some time on the ports, say about an hour on each you can gain 10-15% extra flow. This is all using stock cams. Check out this link for more info. www.flowbenchtech.com/porting/CRH/kz-data.htm
The lift difference is .031", not .008". 8 is the difference in degrees duration @ .040".
Seemed like a worthwhile change that would pick me up 1 or 2 hp for a few bucks.
The lift difference between the stock intake and WC 118 drop in cams is .038", for comparison. Granted that's on both cams with 10 degrees more duration.
But you're right, it may not even be worth messing with. Just rolling it around in my head.
The heads will definitely be ported in the future, I know the value of a good cleanup on a set of heads. Not arguing that fact in the least. I just don't want to pull the heads apart again now the the season just starting.
They were already gone through right before I got the bike and have the first oversize intake valves installed (stock where bent). +1mm I think.
Build Thread
- larrycavan
- Visitor
It's reall not worth messing with.
- tachrev
Build Thread
- racer54
- Thank you received: 114
