***911***** NEED SOME HELP ON THIS ONE!
- Darkangel
13 Apr 2009 20:29 #281526
by Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
***911***** NEED SOME HELP ON THIS ONE! was created by Darkangel
Ok...I just did a custom handle bar build today...and I cut my cables to the length that i needed them on the clutch, right on the perch handle...I figured i would use a cable stop from autozone, drill out the hole, and then install the cable. Well that worked, but now...it keeps sliding out, reguardless of how much I screw the cable down in the stop...So what Do I do....
- MFolks
- Thank you received: 540
13 Apr 2009 20:43 #281535
by MFolks
Replied by MFolks on topic ***911***** NEED SOME HELP ON THIS ONE!
Can you double the end of the cable and then possibly tighten it down? This is an old trick used in electrical crimp on terminals if they come off the wire after crimping.
- Darkangel
13 Apr 2009 20:50 #281540
by Darkangel
Replied by Darkangel on topic ***911***** NEED SOME HELP ON THIS ONE!
double the end of the cable..how...it is in side of the perch handle...The other way I can double it is too insert a screw on the other side...but i would have to cut it off...i might be able to use some solder....The is a brass cable stop..the screw...is probably aluminum or something..Solder will stick to steel wont it...or what else could i do?
- MFolks
13 Apr 2009 20:51 #281541
by MFolks
Another thought, most hobby shops and some hardware stores sell the K&S brand of metal tubing and sheets. They come in many diameter and are very inexpensive; buy some brass tubing to fit the cable,cut to fit your needs and have the tubing act like a shim to tighten down on the cable.
If that won't work maybe some custom cables will have to be made. www.motionpro.com is one place and www.barnett.com is another.
Here's another website for cables:
www.flandersco.com/FlanCableSearch.html
- Darkangel
13 Apr 2009 21:47 #281562
by Darkangel
looking at the fladers site....would you know what I need to make my own custom cables...Because that would probably be the best bet..But still how do they put on the ends...
- timebomb33
- Thank you received: 10
14 Apr 2009 00:05 #281595
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic ***911***** NEED SOME HELP ON THIS ONE!
the cable ends are usally drilled thru then the cable is fed thru the hole and flattened out and then it is soldered over. and the excess is ground or filed off.
