- Thank you received: 1
Valve Clearances Changed after Cleaning Head
- HerrDeacon
Now that everything is back together I rechecked them and now one of the exhaust clearances is tight and one of the intakes is still tight. I don't really mind the intake because it could be my fault in ordering the wrong size shim, but I'm wondering about the exhaust one. Would cleaning everything up possibly change the clearance? I guess some carbon could have affected the gap before it was all cleaned up.
No big deal, I'll just get the correct size shims but was wondering if it was common for this to happen?
- PLUMMEN
- Thank you received: 104
- timebomb33
I THINK MY POWERBAND BROKE
- HerrDeacon
- cornhappy
- bountyhunter
- Thank you received: 337
\Before I put the bike away for the winter I checked my valve clearances and the exhaust were all within spec and the intakes all a bit tight. So I ordered the correct shims, but in the meantime I removed the head and cleaned everything up (combustion chamber and valves).
It's because garbage can accumulate on the valve so that it doesn't close fully. Clean that off and the valve setas and he clearance tightens up. Been there, seen that.
