- Thank you received: 2
Shim Question
- pburnhamb
11 Apr 2009 15:54 #280753
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Shim Question was created by pburnhamb
working on the putting the 750 head back together thats going on my 650-810 project.
I have all the valve clearances pretty close. found a guy down the road that had a bunch of the 13mm shims (under bucket).
the clymer manual isn't too in depth with the whole process. im shooting for .15 and ive got them all to either .12 or .17 (some at .15).
my question is which is better, too much clearance (.17) or too little (.12)? my initial thoughts were too much (.17). since they come in incriments or .05 im not suer which way to go. What do you all think?
thank you.
thank you.
1976 kz900
1977 xs650
- T_Dub
- Thank you received: 25
11 Apr 2009 16:00 #280754
by T_Dub
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
Replied by T_Dub on topic Shim Question
I'd say too much. That way when it breaks in you have more leeway. I'd imagine it'll decrease a fair amount over the first couple of thousand km.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
11 Apr 2009 18:14 #280781
by kzz1p
Replied by kzz1p on topic Shim Question
To much clearance, the shim can jump out. To little clearance, you burn a valve.
- pburnhamb
04 May 2009 14:06 #287886
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic Shim Question
i just realize that i assumed that the 750 and 650 heads would have the same valve clearances. am i wrong?
could someone please tell me what the 750 FSM says the valve clearances should be? is there a range or just a #, all i can find in my 650clymer is .15mm.......i dont see a range.... whats the 750manual say?
thank you
thank you
1976 kz900
1977 xs650
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
04 May 2009 14:55 #287904
by Skyman
West Linn, OR
Replied by Skyman on topic Shim Question
kzz1p wrote:
Do under-bucket shims have a problem with jumping out with too much clearance?
West Linn, OR
- RonKZ650
- Thank you received: 240
04 May 2009 14:55 #287905
by RonKZ650
Replied by RonKZ650 on topic Shim Question
They are all the same. Generally .10-.15mm is what you are trying to get.
- OnkelB
- Thank you received: 80
04 May 2009 14:59 #287908
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Shim Question
Can't help with the 650 vs. 750 clearance specs as I have no info on the 750s (650 spec. is .15 mm as you say), but I'm sure someone else can give you the right numbers.
However, determining shim size you should always round the .05 mm increments up - valve clearance on these engines can only diminish over time so loose is better than tight = .17 mm is better than .12 mm (given the spec is .15 mm).
- APE Jay
- Banned
- Thank you received: 58
04 May 2009 17:20 #287960
by APE Jay
Replied by APE Jay on topic Shim Question
If it has a fresh valve job, it will tighten up slightly.
Jay
Jay
