Cometic one peace head gasket
- kaw74z1
- 0 to 60 in 15 minutes.
10 Apr 2009 19:03 #280463
by kaw74z1
1974 Z1 with a MKII And a 1105 big bore kit 10.5 to 1 comp. Andrews 2x cams ported head dyna s with green coils V&H sidewinder pipe airshifter 4in.over arm
Cometic one peace head gasket was created by kaw74z1
Hi guys, I'm putting my engine back together (kz1000 MKII bored to a 1105) My questions are I'm using a 1 peace cometic fiber head gasket and when I lay it on the block the 4 little hard black things that sit atop the cam chain rollers keep it from laying flush on the block. Do I file these down? also am I correct not to use the O ring? If so what is a good gasket sealer to use. Thanks in advance
- timebomb33
- Thank you received: 10
10 Apr 2009 19:42 #280487
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cometic one peace head gasket
do not shave the rubbers down the gasket and cylinder head will compress them down into place they are there to hold the idler in place so it cant walk around.for the o-ring groove use a good quaility rtv silicone and bring it up flush with the top of the reciever groove. the head gasket must be put on dry all motorcycle gaskets must be installed dry unless specified otherwise.
- mtkawboy
- Thank you received: 16
11 Apr 2009 10:51 #280717
by mtkawboy
Replied by mtkawboy on topic Cometic one peace head gasket
I use the Right Stuff in the grooves instead of the rubber pieces with the 1 piece Cometic gasket. My block is also O-ringed. Been that way for the last 8 years with no problems
- kaw74z1
11 Apr 2009 11:21 #280723
by kaw74z1
Replied by kaw74z1 on topic Cometic one peace head gasket
Right stuff is that a gasket sealer? also the black thingys (btw) what is the name of them? are realy hard should they be hard or pliable.
