4-2 cross over exhaust
  • kwakagoose
  • kwakagoose's Avatar
Re: 4-2 cross over exhaust
04 Mar 2006 07:11
#28138
sounds pretty good but not as nice as a kerker 4 into 1.
Post edited by: kwakagoose, at: 2006/03/04 10:14
  • dan76kz900
  • dan76kz900's Avatar Topic Author
04 Mar 2006 08:18
#28156
jtmcculloch: Did you get those new pipes on yet ? Did you gain ground clearance ? how much ?
Those pipes you bought, they are not the cross over type I am thinking of, but they have a equalizer tube. Yours have exhaust pipe 1 and 2 collect, 3 and 4 collect. The cross over I am thinking of has 1 and 4 collect, 2 and 3 collect, and has no equalizer tube.
BTW Jtmcculloch, your bike is beautiful ! I bet it'll be nicer with those pipes.
  • kz10cubed
  • kz10cubed's Avatar
04 Mar 2006 11:23
#28185
I have a 78 Kz1000ltd. Does anyone know if the 4 into 2 exhaust system on the standard 'A' model will fit on the ltd model? Thanks Kirby
  • jtmcculloch
  • jtmcculloch's Avatar
04 Mar 2006 15:49
#28228
Not yet, I wont get them till the end of next week.
I should get 2" more
>BTW Jtmcculloch, your bike is beautiful ! I bet it'll >be nicer with those pipes.
Thanks
76 KZ1075
93 ZR1100
05 Honda ST1300
71 Moto-guzzi 750
  • nfswift
  • nfswift's Avatar
04 Mar 2006 20:05
#28296
I have this exact stock megaphone exhaust system for my 650 CSR, I have circled points near the crossover where each half of the header collects together, I am worried of this spot as it looks like a REAL bottleneck, not to mention the pipe leading off from it towards the megaphones (including crossover) is very small diameter pipe, I'm wondering if this is such a good stock exhaust to be running? C:\Documents and Settings\Jer\My Documents\My Pictures\4-2.JPG[/img]
  • The Milkman
  • The Milkman's Avatar
04 Mar 2006 23:23
#28314
dan76kz900, if you are talking about the Jardine type system where #1 crosses over and goes out the right side with #4 and #3 goes out to the left side with #2 like I have on my 650 it helps with the scavenging of the exhaust because the pulses alternate from side to side. The power pulses on the 4 cylinders go 1,3,4,2.
I know someone is going to bring up that the ignition timing cycle is 1,4,2,3, but that has nothing to do with the power firing order.
With this system the exhaust pulses go left right left right. where as on a stock system the pulses go left right right left.
  • dan76kz900
05 Mar 2006 08:36
#28363
milkman: Yes ! I dont know if its a Jardine system or not. Now I know the diffrence.. So with improved scavenging, I should gain or free up some power ?
Where can I buy this exhaust system ?
  • TLH101
  • TLH101's Avatar
05 Mar 2006 12:06
#28405
Shoe,
Here's a pic the 750 4-2 on my 78 KZ650:
  • steell
  • steell's Avatar
05 Mar 2006 12:29
#28417
Ok, no free rides, you need to explain that one :D
Power pulses have to match the firing order, can't have a power pulse until there has been a spark event and the mixture ignites :)
The 650/750 firing order is 1-2-4-3 and I assume the 1000 is the same, 180 degrees of crankshaft rotation between each power pulse, 720 degrees (two rotations of the crank) till all cylinders have fired.
So the power pulses are actually going to be 1-2-4-3.
  • Rickman
  • Rickman's Avatar
06 Mar 2006 10:59
#28684
Probably, 1100 is the same.
Goose, Google tells me that Jardine J8102 seems to be for a Yammy XS1100L. Had you heard that it fit, or did Jardine used to make them for the KZ?
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
