Shims Shims Shims
- Pro_window78
09 Apr 2009 16:20 #279989
by Pro_window78
Shims Shims Shims was created by Pro_window78
Anybody know where an inexpensive shim kit can be found, preferrably with the valve tool? Thanks -Ryan
- timebomb33
- Thank you received: 10
09 Apr 2009 18:38 - 09 Apr 2009 18:41 #280037
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Shims Shims Shims
for which bike they have different sizes and styles shim under bucket or shim over. i bought a set of shim under shims from k&l supply last year. it came in a kit.about ten different sizes and it still isn't enough shim over shims i probably have 200 hundred or better.
Last edit: 09 Apr 2009 18:41 by timebomb33.
- bountyhunter
- Thank you received: 337
09 Apr 2009 22:42 #280147
by bountyhunter
Replied by bountyhunter on topic Shims Shims Shims
back when I was looking I saw the 28mm shim kits all over the place.
If it is the 32mm shims for a 750 twin, they do not exist amymore.
- BSKZ650
- Thank you received: 14
10 Apr 2009 06:34 #280254
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Shims Shims Shims
z1 has kits and tools, but then again,, which bike
- Pro_window78
10 Apr 2009 19:26 #280473
by Pro_window78
Replied by Pro_window78 on topic Shims Shims Shims
Sorry guys, 78 kz1000
- bountyhunter
10 Apr 2009 22:30 - 10 Apr 2009 22:50 #280559
by bountyhunter
Pro_window78 wrote:
I believe they are 29mm diameter shims.
This site shows the shims and changing tool:
www.kz900.com/kz900a/cam-shaft.html
KZ900 and KZ1000 use the 29mm shims.
Last edit: 10 Apr 2009 22:50 by bountyhunter.
- darmahsd
11 Apr 2009 19:12 #280814
by darmahsd
Replied by darmahsd on topic Shims Shims Shims
Talk to the service manager at the local Kaw dealer. Many
(mine) will swap out shims with you because they don't wear, whether under or over the bucket.
Stephen
Stephen
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
11 Apr 2009 19:33 - 11 Apr 2009 19:34 #280825
by kzz1p
Replied by kzz1p on topic Shims Shims Shims
darmahsd wrote:
I'm sorry to say, but some do wear.
Stephen
Last edit: 11 Apr 2009 19:34 by kzz1p.
