Anyone Familiar with Adding Nitrous??
  • 79MKII
  • Topic Author
  • Love Them Kaws!
08 Apr 2009 11:47 #279546 by 79MKII
I am seriously considering adding nitrous to my KZ since the turbos are so expensive. Can nitrous truly be added to any engine as I have been told? What modifications are truly necessary? Any info would be greatly appreciated. Thanks!
The Kaw List:
08 Apr 2009 11:54 #279548 by timebomb33
Replied by timebomb33 on topic Anyone Familiar with Adding Nitrous??
heavy duty studs ,o-ringed block, heavy duty clutch basket and possibly lots of other things dependent on ponies required.
I THINK MY POWERBAND BROKE
  • 79MKII
  • Topic Author
  • Love Them Kaws!
08 Apr 2009 12:02 #279550 by 79MKII
Replied by 79MKII on topic Anyone Familiar with Adding Nitrous??
The engine is definitely pretty beefed up, but I don't have an o-ringed block.
Is a fuel pump necessary like the turbos require? A heater for the bottle?
The Kaw List:
08 Apr 2009 14:24 #279601 by irishwill
Replied by irishwill on topic Anyone Familiar with Adding Nitrous??
where are you gonna run it strip/street?
how big a shot?
progressive or WOT only
are a few questions you need to answer.
some answers,
yes you will need a fuel pump
you should atleast weld the crank and run a lock up clutch
no you dont "need" a heater
should have a way to pull timing out of the motor as you spray
heavy duty studs really good Idea
just my .02
08 Apr 2009 14:25 #279602 by timebomb33
you get a fuel pump with the kit when you buy it.if your racing get a bottle heater but if just giving it a squirt on the street every now and then i wouldn't waste my money all the blanket does is keep the bottle pressure more consistent.
  • 79MKII
  • Topic Author
  • Love Them Kaws!
08 Apr 2009 15:06 #279611 by 79MKII
OK - good information. The kit I was looking at included a "progressive controller" but I'm not sure if I'd shoot it except at WOT. The controller is for the nos and not the ignition, right?
My crank is welded, ape studs/nuts, 1260 kit, o/s ss valves, ported head, crank support, windage tray, etc... but just removed and sold lock up :ohmy: Frame is braced as well and everything is pretty much set up for the HP.
It would be street mostly with an occasional night at the drag strip. I have an MSD mc-1 ignition but I don't think the timing is adjustable.
So the higher compression is OK? Not like a turbo where low comp is required? I have the 10.5 to 1 MTC pistons in there now.
Thanks!
The Kaw List:
08 Apr 2009 17:30 #279632 by timebomb33
nitrous motors love compression and super good fuel so if your gonna play be prepared for the odd jug of race gas
08 Apr 2009 19:11 #279694 by PLUMMEN
Replied by PLUMMEN on topic Anyone Familiar with Adding Nitrous??
start with a really small shot to see how you like it!:laugh: i thought about running it on my turbo bike to help get the turbo spun up but since i broke my foot ive had some time to reflect on that idea,ive definately decided against it!:S :woohoo:
08 Apr 2009 22:27 #279817 by APE Jay
Replied by APE Jay on topic Anyone Familiar with Adding Nitrous??
The only problem with nitrous is that it is so cheap to keep adding power. If you can reasist tghat and just run the jets that come with the kit, you will be fine.
Nitrous
09 Apr 2009 00:14 #279823 by donthekawguy
Replied by donthekawguy on topic Anyone Familiar with Adding Nitrous??
Nitrous
Hey Jay to many beers? :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
09 Apr 2009 01:01 #279825 by jordan
Replied by jordan on topic Anyone Familiar with Adding Nitrous??
If all goes right i will be running nitrous on my 1000 when its done, and after i get it good and rideable. I was thinkin 50 shot max for the strip. A member on here drags a zx-12 that helped me out quite a bit when i was looking for nitrous information. Good Luck
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
09 Apr 2009 04:41 - 09 Apr 2009 04:43 #279841 by otakar
Replied by otakar on topic Anyone Familiar with Adding Nitrous??
Hay Jay;
How adjustable is the horsepower you want to add? Say I only want to add 20 Hp to a motor that already has 135, for the street? Is welding the crank a must? At what Hp do I have to weld the crank on a "J" motor. Mine is an 1135 11:1 with "Your" K410 cams and a very well flowed 84GPz head, GS1150 BS36 stage 2 carbs. I would want to totally hide the bottle. what are the bottle dimensions?
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 09 Apr 2009 04:43 by otakar.
